You can create your own variables and change their values. When using
variables, the following guidelines apply:
- Variable names are case insensitive and are limited to 32
characters.
- The variable name must be unique.
- A variable can be referenced as $X or
$(X).
- If a variable already exists, it is overwritten. No error message
is displayed.
- The variable expression can be a constant value, another variable,
or a combination of the above with operators and functions. Operators are described in ,
and functions are described in .
- Only the set var
command supports expression evaluation.
- If the variable name X contains special characters such as +-/*,
then the variable needs to be enclosed in parentheses. For example: set var z ($(x) +
100).
- When you use a variable with a TCL special character in the $TCL
function, the variable must be enclosed in braces. For example: set var x $TCL(string
length ${CLI.USER}.
- For more information on TCL functions,
see Using Built-In Functions.
ExtremeXOS does not
consider the dot/period character as a de-limiter. This is different from standard TCL
behavior, where dot/period is considered as a de-limiter.
